Shawno1531
I am looking for some imput as to why my engine is cutting out on me at low rpms. Upon start up (especially if the engine is cold) soemtimes will start very hard unless i give it some throttle (while in neutral) and cranking the engine. If i shift it into drive once i get it started while at a very low rpm (maybe around the slow no wake speed) it tends to turn off and cut out on me unless the engine is warm. Also if I slowly give it throttle it will shut off unless i give it a lot of thottle or move it back to neutral real quick. Could it be a EGR valve? Not sure if i even have one.
