My 2000 Mercruiser 5.0L with 2bbl carburetor tends to be hard starting if the boat has sat for several days or longer. I'm fairly certain this is a fuel delivery issue and not spark related. If you squirt a little fuel in the carburetor after setting the engine fires immediately. I don't do this regularly but have squirted in fuel just for troubleshooting. Once started for the first time it runs just fine and starts easily after turning it off. This issue has existed the last few seasons and I didn't give it much thought but now it's really bugging me.
My 32 gallon fuel tank is below the floor and sets lower than the fuel filter and engine. When the boat sets for a while I don't smell any excess gas fumes and I don't see leaks anywhere. When the key is in the on position I can hear the fuel pump spin up but it takes several repeated tries cranking the engine until it finally fires.
Could this be the anti-siphon valve? My understanding is this valve prevents an auto-siphon condition from the tank to the engine so that the carb doesn't flood out with fuel when the motor isn't running. But, I also thought this acts like a check valve and keeps the fuel line loaded and prevents fuel from draining back to the tank. Is this correct?
Please let me know if you have other ideas to check into.
KJ
KJ
