Yes, that's what its called in the shop manual.By drain hose connector do you mean the flush valve port at the back of the motor?
Working great, no red light, good flow from the telltale.
I know this is an older thread but I have a question that I hope you can answer. When all was said and done, did the lower unit still have water coming from all the small holes and the large hole behind the pitot tube? Mine is doing that and I don’t recall it doing that last year. Thank you!
I think so, I don’t yet have it in the water this year, been doing some other things and won’t have it in for a couple of weeks to confirm.I know this is an older thread but I have a question that I hope you can answer. When all was said and done, did the lower unit still have water coming from all the small holes and the large hole behind the pitot tube? Mine is doing that and I don’t recall it doing that last year. Thank you!
Inshore-you are getting sand or debris due to shallow water?
I own a 130 hp and have had this problem many times I give you a tip it solved my problem once and for all .Take the thermostat out and use Durbans Formula it does not only solve the problem it also cleans the motor up inside from salt build up over the years pour it in block the pee pipe, in the thermostat reses you will notice that when the thermostat opens water goes down there as well pour it in and leave it for 2 or 3 days .then after flush it on muffs. I mixed Durbans Formula 3:1 with water. 3 water and 1 Durbans Formula.
I also changed the cylinder head and put brand new later model one on you will notice on the new ones they machined the water flow passage better my old one cracked and i give Honda 100% credit on the new cylinder heads
Yes its sand and whatnot from running shallow.
Durbans wont hurt the steel parts?
I don't think there's a new cylinder head or gasket available for the BF130 anymore. If so that would be great because I have another BF130 on the rack with gasket or head failure.
My proof is already in the pudding. If you ever have the opportunity to come to Hamilton New Zealand i will show you how Durbans Formula works and the fantastic results .
