I am new to owning an outboard motor, but have a good level of mechanical experience. I am having trouble with a (new to me) Honda outboard. I have been reading bunches, and can't figure out my problem.
2006 Honda 8HP 4 stroke, bought on consignment from a dealer. Dealer checked the engine, compression is good, motor not used much. (It does look brand new)
Upon using the motor, it was fine, ran exactly as I expected. Brings the boat up out of the water, and probably achieves close to 15mph. New gas, which is only a week or so old.
Used the boat one day, and parked it in the water. It was fine on the short trip there. Next day, I went to take it fishing with my daughter, and the boat started fine, ran fine, but would not accelerate or rev up past about 1/4 throttle. Idle was a little less than ideal, but didn't really stall out unless it idled for a good amount of time. I thought maybe there was something clogging the cooling system, so I took the boat home and ran it in a tank of clean water. Checked the oil, it appears to be correct. Reading led me to believe maybe it was not getting adequate fuel. Next time out, the boat ran perfectly, all the way up to full throttle. Took the boat home. Filled the tank up again with new gas.
Trip prior to last, I disconnect the fuel line to see what happens when I run the boat dry while it is running fine. It goes fine to the very end and shuts down. I put it on the trailer with the trolling motor.
Last trip by myself, after running it dry, boat started right up, parked at the dock, shut it down. Jumped back in, boat ran great for about 10 miles. Stopped to fish. Started right up to go home, but boat would not run past about 1/4 throttle. It doesn't bog down, it doesn't sound bad, just won't go fast. I can turn the throttle up a couple clicks, and then after that it makes no difference how far it's turned. Cruised back the 10 mi or so very slowly. Toward the end it was getting a tiny bit worse, but only after the hour or so it took to get back. I tried stopping, and re-priming. I tried pumping the primer while running, no effect. Put the boat on the trailer and came home.
After much reading, I checked the fuel supply. The bulb is pumping into the filter, which is about 1/2 full of gas. The tank looks clean, the dip tube appears to be fine. I thought maybe it was cracked, but it has run fine on 1/2 tank, and bad on full tank, so I think that's not it.
The bulb doesn't firm up like I think it should, but I can see it is pushing gas, and have confirmed the gas is getting all the way to the carb plug. Fuel supply lines appear in good condition. I am opening the tank carburetor, the oil light is on, boat is peeing, and I think I'm running it exactly as the manual suggests, with the exception of trying the primer once while running slow. Throttle linkage mechanically functions perfectly.
I'm thinking maybe the bulb is bad, and have ordered a new one, but I'm not sure because the motor isn't really stalling or anything except at dead idle for extended period of time. Also, running with the fuel line disconnected when it was running good didn't seem to bother it, which I would think a bad bulb would have choked it out almost immediately in that situation (it took a good few minutes to burn up what was in the fuel line). It's like the motor is either 100% or 25%, with nothing in between, and this can be apparently be caused by something as simple as shutting it down to fish an hour, and then restarting. Not sure if something is clogging the carburetor, but that also doesn't seem right to me, because it runs fine, even when it won't hit full throttle, and there appears to be no variation except it runs full bore, or doesn't.
Any diagnostic ideas or knowledge on why this is happening?
