Higher at idle orfull throttle?
If your full throttle, on plane, rpm is higher, check your prop hub and make sure the rubber isn't deteriorating.
If the idle is suddenly higher than normal it could be a few things.
An intake leak...a stuck open thermostat...a failed engine coolant sensor....excessive fuel pressure if it's fuel injected.....a mis-adjusted choke if it's carbureted....sticky throttle linkage or cable...and probably a few other things that escape me at the moment.
It depends on what "it moves a bit" means.
There is some "inherent" movement in the transmission gear train so that, if the trans is locked in gear with the engine off, you can "rock" the prop back and forth a small distance as you take up the "slop" in the gears. But, when you move it that slight amount, in either direction, and remove the gear lash or "slop", you shouldn't be able to budge the prop any additional distance by hand. It should be completely locked tight. If it fails this little test, your prop hub is going bad and that IS the reason for your increased rpm.
I hope I made this clear enough for you to make a determination.
WARNING! Any time you are manipulating a prop by hand, keep the ignition off and the kill switch lanyard pulled for safety.
Good luck.
Another way to check, is to scratch a mark on the prop near the prop nut. Then also scratch a mark on the prop nut next to your other mark. You can use a knife or a center punch.
Then go run the engine under load on the water. Do several accelerations to put a lot a strain on the prop.
After your run, check the marks. If they moved away from each other, the prop has spun.
Mike
Just as an aside - whether your prop is spun or not, one of the things I've learned the hard way is to always carry a spare prop, castle not, flat washer, thrust washer, and cotter pins on the boat. Often, a spun prop will not fail completely all at once, but rather, over time, you will experience some slipping on acceleration. Don't ignore that.
Mike
Yes, growth on the hull creates drag and the engine has to work harder to achieve the same speed.
Is your rev counter is set correctly on the back? I've heard that they can sometimes need checking.
