What did you find ??
I would like to thank fdrgator for the drive shaft advice.
I just got back to working on it and I was mistaken. The waterpump is not working.
Update: After removing the lower unit a few timesand inserting the drive shaft into the crankshaft I was able toget the prop to turn when I pulled the cord (sparkplug wiresremoved). When I put it into a tub of water and ran the motor theprop would not turn.
Before I buy a driveshaft is thereanything else I can try to insure it is thedriveshaft?
Also, I see there are 2 drive shafts in the parts liststandard and long.
My SN is 3034-07467.
Is that standard orlong?
Clutch problem? Not fully engaging under load. Also fix that water pump problem first.
