Results 1 to 6 of 6
    Sep 2016
    Ashtabula, ohio
    18
    Default Mercruiser 5.7 running on 7 cylinders
    Hi, I have a 1990 larson san marino with a mercruiser 5.7 in it. Bought it last year in the fall and just got the plugs changed on it this week and the shop said it's running on only 7 cylinders. They said they are not getting and spark from the cap for that cylinder. They tried new wires and nothing. Any thoughts on what it could be? Thank you.
    Jun 2006
    Spotswood, NJ, USA
    4,376
    Default Re: Mercruiser 5.7 running on 7 cylinders
    if its the flat dist cap, replace it
    Sep 2016
    Ashtabula, ohio
    18
    I'll have to check it out, it's still at the shop haven't decided if I was gonna have them go thru it or work on it myself
    Mar 2009
    Portland, Oregon,
    10,308
    Quote Originally Posted by Jsucci View Post
    The ignition coil doesn't know which spark plug wire it is sending spark to.
    The sensor unit doesn't know or care either.
    The distributor cap does have an important involvement....... has the cap been replaced?
    If this is a Merc TB photo-eye triggering system....... the photo-eye wheel may be defective..... has anyone checked this?
    If this is truly an issue with NO spark being delivered to #7 cylinder, and yet you have good spark to all other cylinders...... and if this shop cannot figure out why........ I would quickly find a new shop before they end up replacing everything at YOUR expense!
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Sep 2003
    New Tripoli, PA, USA!
    15,768
    Damn good advise!
    Jeff
  6. #6
    Jun 2008
    Island Heights, NJ,
    2,931
    re: " and if this shop cannot figure out why........ I would quickly find a new shop before they end up replacing everything at YOUR expense! "
    I would amend this to say... "If they could not figure it out the first time....I would quickly find a new shop." I would not give this incompetent ( kindest comment) or dishonest shop another shot.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  1. Seems to not be running on 2 cylinders
    By Edward Koegler in forum Mercury Mariner Outboard Forum
    Last Post: 01-03-2016, 07:27 AM
  2. 90 running on only 2 cylinders
    By mercnav in forum Johnson Evinrude Outboard Forum
    Last Post: 04-01-2013, 11:01 AM
  3. Only running on 2 cylinders
    By jonny_boy in forum Johnson Evinrude Outboard Archive
    Last Post: 05-10-2009, 12:47 PM
  4. 350 57 running on 7 cylinders
    By bill netto in forum Marine Power Engine Forum
    Last Post: 03-23-2008, 02:43 PM
  5. Running only on 2 cylinders
    By Robert Blessing in forum Archive 2003-2009
    Last Post: 05-18-2004, 11:38 PM
