Results 1 to 5 of 5
  1. #1
    Join Date
    Mar 2015
    Location
    Deale, Md.
    Posts
    28
    Default Intake manifold gasket, cork or silicone ?
    Putting the intake manifold back on my 454. Fel Pro gasket set comes with cork strips for the ends. Should I use them or discard and use RTV ?
    Any other tips or tricks ?
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,402
    Default Re: Intake manifold gasket, cork or silicone ?
    clean surfaces with alcohol, place 1/4 inch bead of black RTV , set manifold, let cure, torque to spec
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,418
    the factory recommendation is to use the gaskets from the kit over the head ports and RTV acrosss the "short ends"...
  4. #4
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,776
    Traditionally, we always add some sealer where the gaskets meet at the ends.
    Jeff
  5. #5
    Join Date
    Mar 2015
    Location
    Deale, Md.
    Posts
    28
    Thanks Guys !!
Similar Threads
  1. Intake manifold gasket
    By Crunchy21 in forum Honda Outboard Forum
    Last Post: 03-22-2018, 11:58 AM
  2. intake manifold gasket - sealant/bolts
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 04-16-2014, 07:20 PM
  3. Intake manifold gasket
    Last Post: 11-26-2013, 09:08 PM
  4. Intake manifold gasket blew at crossover
    By craig_collins in forum Crusader Marine Engine Forum
    Last Post: 06-16-2013, 10:22 PM
  5. Leaking Intake Manifold gasket
    By Michael Shelby in forum Mercruiser Sterndrive Archive
    Last Post: 12-31-1969, 07:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
