Results 1 to 5 of 5
    Default Johnson 225 dies when key is released
    I have a 1993 Ocean Runner 225 that starts easily then dies when key is released from "start" position to "run" position. Same occurs when kill switch and shift interrupt switch are disconnected. And same when port temp sensor is disconnected. I also replaced the ignition switch. I still get the same problem. I double checked the function of the new ignition switch and all is according to specs. I recently replaced the flywheel, stator, timer base and power pack because they were all bad. I'm completely baffled at this point. Any ideas?
    Thanks,
    Mike
    Feb 2001
    Central West Florida
    14,738
    Default Re: Johnson 225 dies when key is released
    ^^^^ BUMP
    Mike... I received you PM explanation, however I retired in 1991 so your wiring setup may have changed from what I'm accustomed to so I'm bumping this back to the top shelf for the more knowledgeable members of your 93 model to view.
    We occasionally have questions. If you fail to answer, it may affect ours.
    Thanks Joe. A guy at CDI suggested I disconnect the yellow/red stripe wire that comes out from the power pack. I tried it and it ran, briefly. It wouldn't start after that. More trouble shooting tomorrow.
    Apr 2010
    4,321
    Is your ignition switch wired correctly ??
    Nov 2011
    tennessee
    3,076
    Unplug the wiring harness and jump the solenoid . If it starts and run the keyswitch is the problem.!! MAKE SURE WATER IS HOOKED UP!!
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  1. Crusader 454 Runs till Start button is released
    By RobertG in forum Crusader Marine Engine Forum
    Last Post: 10-13-2016, 06:56 PM
  2. Evinrude 85 HP - no spark unless compression is released ( `77 model )
    By GpFinn in forum Johnson Evinrude Outboard Forum
    Last Post: 04-09-2014, 09:35 PM
  3. mid 80's motor wants to run at full choke but dies off released
    By jwysong in forum Johnson Evinrude Outboard Forum
    Last Post: 08-11-2010, 06:09 PM
