Click forPleasurecraft Marine parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default 1988 PCM 454 runs rough over 3000 rpm and once warmed up
    Finally have my boat in the water. Starts fine, idles good and runs good. Once warm it sounds like it is starving beginning at 3000 rpms. Giving it more gas does nothing. When you put in neutral in quits and then is hard to start. Seems like it is not getting gas. I replaced in line gas filter and now will begin process of elimination. Any advice on a priority list of items to go through. I will also replace plugs and wires and would like a recommendation on good wires. Thanks much
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,000
    Default Re: 1988 PCM 454 runs rough over 3000 rpm and once warmed up
    I'd be inclined to check and make sure the timing advances correctly.....and then verify the fuel pressure, under load, across the RPM band.
    If its is fuel starvation, don't run it any longer than necessary.....could be the tank vent is restricted or the anti-syphon valve is clogged, debris in the tank, fuel pump, etc....
    basically, be methodical and keep good notes in your log book.....make one change at a time until the problem is found...
Similar Threads
  1. 2005 mercury 9.9 Prokicker runs rough, runs good after 15 minutes
    By FireNHunt in forum Mercury Mariner Outboard Forum
    Last Post: 04-22-2016, 10:04 PM
  2. 1991 48 hp SPL runs great until warmed up, then shuts down to idle.
    By rhen74 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-25-2014, 09:23 PM
  3. 99 PCM 351 runs rough after warmed up
    By h2oskier in forum Pleasurecraft Marine PCM Forum
    Last Post: 04-21-2014, 10:07 AM
  4. 1988 15 force needs starting fluid ot start and will not idle when warmed up
    By shermanpup in forum Chrysler Force Outboard Forum
    Last Post: 07-17-2013, 07:48 AM
  5. Yamaha 99 four stroke runs rough until warmed up
    By the_billy in forum Yamaha Outboard Archive
    Last Post: 01-04-2009, 02:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
