Our boat has twin 2002 Honda 200's. Last week I was 30 miles offshore and turned both motors off while drift fishing. When starting the Starboard motor the starter briefly loaded then turned over normally. The engine started but ran rough and seemed to have a knocking. I shut the engine down and pulled the engine cover to check. All appeared well, but there was water in the oil.
After checking the motor at home, #6 cylinder had 0 compression and cylinders 1 + 3 had 140-150 lbs of compression. All other cylinders were 190-200 lbs. Neither motor had SB#56 performed on it when this took place. I understand that #6 cylinder possibly ingested water and could have blown the head gasket. I'm not sure where the water in the oil is coming from? It might be a head gasket leak between 1 + 3, but not sure. I drained the oil/water and filled with new oil.
I have decided to either install a new short block or buy two new motors. The short block doesn't appear to be to terribly difficult and they are actually a reasonable price from Boats.net. So I'm leaning that way.
I really appreciate all the knowledge that I've gleaned off of this forum and I'm sure that one of you can help answer the following questions:
Thanks for the help!
- What are the paths for water to mix with the oil...and how do I prove that is the issue? (Head gaskets, cracked head, etc, etc, etc)
- I have the factory service manual, which is very helpful, but is there anything special to watch out for when changing the short block?
- Will the new short blocks have better corrosion protection than the original 2002 blocks? (This block had bad corrosion near the Port side thermostat housing)
- I will perform the SB#56 mods, anything else that I need to do while performing this work?
