So, I reset the cam rod by loosening and re-tightening the brass coupler.
Dribbled some WD-40 down the cam rod towards the cam rod bushing.
And, cycled the shift lever quite a few times with the engine horizontal (oil inside the gear case).
It shifts quite crisply, now.
Although, I have not started the engine, yet.
One thing I did notice is that the engagement of the "starter lock cam" with the "starter lock"
(up at the top of the recoil starter) seems a bit off. See the attached photo (engine in neutral).
The part number for the "starter lock" is 3R1052520. Apparently, it is an "OLD" part.
Has there been a redesign of this mechanism? If so, what are the new part numbers?
(Couldn't get the photo uploaded...will try again later).
