Hi
93 Galaxie OMC King Cobra, rebuilt crate Chevy 5.7L, spread bore Holley 650b carb
Back on the water this spring and pulled carb to get inserts installed to repair carb bowl bolt hole that I stripped last year. Put in new kit. When I go to start engine I have to give it full throttle to get it to start. It runs rough but will idle. I have checked timing as best as possible and looks to be 8 degrees before TDC per manual. Last year, I could start it with one bump and it idled perfect.
I know it has to fuel or fire or both. Trying to figure out where to start. When I pulled plugs they looked to be fouled by fuel. Plugs were black but dry however smelled like fuel. I cleaned and reinstalled and had same miss.
No matter how I adjust the carb adjustment screws it does not seem to make much of difference.
What is best way to check fire at the plugs. Its hard to get my head down into engine compartment to see the spark. Any tips?
