Results 1 to 3 of 3
    Default 1998 50hp johnson outboard.
    Can anybody tell me if this motor has a shear pin? Was cruising across the lake when it suddenly felt like it went out of gear. it had enough push while idling to get us back but foward and rev feels like its free wheeling. Didn't any loud noise or grinding sounds. Thanks for your help.
    Sep 2010
    ontario
    16,509
    Default Re: 1998 50hp johnson outboard.
    No shear pin.----But it has a rubber drive hub / shock absorber in the prop.----Try another prop.----Might not hurt to check / change gear oil too.
    Quote Originally Posted by racerone View Post
    Ok, thanks. Gear lube was changed/checked yesterday.
  1. Have stuborn 8hp 1998 johnson outboard
    By tjh61478 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-18-2011, 06:52 AM
  2. 1998 johnson 99 outboard no power
    By chris horton in forum Johnson Evinrude Outboard Archive
    Last Post: 07-27-2008, 04:49 PM
  3. 50hp Johnson outboard
    By spider27monkey in forum Johnson Evinrude Outboard Archive
    Last Post: 04-04-2007, 08:05 AM
  4. 1998 175 Johnson Outboard
    By rroshelli in forum Johnson Evinrude Outboard Archive
    Last Post: 02-20-2007, 01:06 PM
  5. 1998 225 Johnson Outboard
    By matt in forum Outboard motors archive 2000-2004
    Last Post: 10-26-2002, 08:56 AM
