InstaGator
I've used this site a few times for help and almost always get someone who posts the fix for it so why stop now right? I've got a 98 Searay with a 5.7 Mercruiser in it. We haven't used it much the last few months but we do hook the hose to it and run it for a few minutes a couple times a month. Three weeks ago we took it out and it started right up and would go almost full throttle(RPMs were just above 3,000) and then it would try to go wide open sometimes but just for a second or two. So I syphoned the gas out and put fresh fuel with about half a can of seafoam. I took it out today and it did the same thing at first but it got worse and worse and eventually wouldn't even go 1/4 throttle without shutting off. It idles great and it can go into gear but not much above an idle. On the way back to the dock I noticed the battery volts were just above 12(usually they're about 14). I got back to the house and checked the screen in the fuel line, they looked good, the carb looked pretty clean but I just looked from the top I didn't take it apart. I looked at the alternator and saw the positive wire was pretty looks and looked burnt, so I fixed that and put the wire back on tight. I have not taken it back out yet but my big question is, could that alternator wire being loose and causing the battery not to charge properly cause it to not run WOT? I would think if it was fuel related it would at least run the same if not better, but it getting worse has me stumped. I have not checked the plugs because they are a pain to get to but that is my next step and then a full carb rebuild if that doesnt work. Any suggestions? I havent checked a lot yet, but before I go changing a bunch of parts I figured I'd ask the experts. Thanks in advance, you all have been a great help on my many projects thus far.
