I have 2 1998 TAMD73 Engines in a Navigator 53. They have about 2,000 hours.
* both surveyed by Volvo tech 18 months ago @ purchase
- port temps 170-175
- stb temps 170-180
- no issues of any kind
* I´ve put about 400 hours on the engines in last 18 months, 90% at low (1400) rpm
* I replaced both impellers, themostats, and coolant 3 months ago as a preventative measure
* both run at 170 degrees while when at 1400 rpm, my usual cruising speed of 9kts
I took trip this weekend (100 miles) and as usual ran up to 22-2300 rpm at end of 7 hour run to get engine up to temp for 15 minutes or so. Port engine fine, but starboard temp ran up to 190 degrees or so. On reducing rpm back to 1400, temp quickly reduced back to 170.
on stb (overheating) engine:
* seawater strainer clean
* checked impeller, it was fine
* some wear on the seawater pump plate at the cam, but port engine was same
* coolant level good
* impossible to really determine water flow, but at idle, seems fine
Any guidance appreciated!
- stb temps 170-180
