ryandavisl
Having issues with my 1998 Johnson J25 elece. It will start up first or second try with fast idle lever up a little, then i let it warm up with fast idle lever up, when i run the motor WOT it runs perfect but anytime we try and go slow or always when i put it in neutral it stalls out.
Every once in a while it will stall out when i start the motor after trolling for an hour or so, it will start right up as i give it throttle it takes off then bogs down and stalls.
Engine was recently completely rebuilt from top to bottom (6-months ago). Any ideas what could be causing this?
1998 Johnson 25 hp 2-stroke- model- J25 elece- remote operated.
thanks in advance for any advice.
Ryan
Ryan
