Carson0307
The carbs have been cleaned and spark plugs have been replaced.
What's the compression on it ??
Ok I’ll check that tomorrow and let you know. Thanks.The model # of the motor should be on the side of the transom bracket. The CDI box may be mounted on the side of the motor it will have a cd2 printed on the side of it. Black box with wires coming out of it.
The model number is -E48ESLESAThe model # of the motor should be on the side of the transom bracket. The CDI box may be mounted on the side of the motor it will have a cd2 printed on the side of it. Black box with wires coming out of it.
well I looked up there guide at its kinda complicated and I don’t have any good boat shops that will work on it i love in Sumter SC and the a some seriously bad shops near me so there not an option and the good ones don’t work on evinrudes so idk what I’m going to do.OK you need to go to www.cdielectronics.com find their troubleshooting guide for your ignition. You have the UFI ignition system that means you power-pak is under the flywheel. That ignition system can be troublesome and cause the problems you are having. Your motor is a 1990 model.
