Old Vintage Merc
I thoroughly disassembled the carburetor and soaked it in Seafoam. I removed the main nozzle and used mono fishing line in the small holes. It's very clean, I'm not sure it was even dirty. There were really no traces of contaminants at all. Perhaps they dissolved if they existed. I checked the linkage for the throttle and choke lever. They are positioned correctly, the choke plate is fully closed when the choke knob is out. The throttle plate goes from closed to maximum open when turning the throttle handle from the Shift position to Fast. The plates are not constricted, they easily open and close. After reassembly I primed the ball and when I forced the issue gas squirted out of what I suppose is an overflow hole? The motor will start easily with the choke pulled out. The engine runs really well. When I depress the choke knob the engine flat out Races! Hmm...
