Sandkicker, I don't think my drive is the same as yours and there is no cross pin on my transom shield to pivot the drive on
The 250 through 285 set pin (that Bob mentions) is a horizontal shaft that the Non-Hydraulically operated suspension fork comes up against during FWD thrust. Your C drive Suspension Fork is hydraulically operated.
All AQ series drives articulate on a "pivot tube"...... including your C drive.
Thanks RicardoMarine, that little spring pin was hard for my old fat fingers to hold on to but I got it. I did this job about 7-8 years ago so I remembered basically how to do it. So far the U-joints and eccentric piston seal are done. The old piston seal was double lip but the one I received this time - OEM Volvo- was single lip.
The new eccentric piston seal must seal against gear oil and against water. This is why they are double lip.
https://www.wholesalemarine.com/sea...2c289c&gdfms=4343C7FEFE0042F6AFE1CBFFFE7487B4
I installed it with the lip facing aft as there were no instructions.
There is a small thin area whereby the metal body is exposed. This side faces IN towards the gear oil!
Hope I did this right. As far as the upper gear housing not wanting to come off with out a fight, I was thinking the orientation of the crosses might have had something to do with not being able to lift the gear housing straight up enough to free the splines if that is possible.
In all my years of doing AQ series work, I have never experienced that!
