I've determined the starboard temp sensor is stuck in the closed position.
I want to check out the port sensor, but it's stuck in there pretty good, and I'll probably have to break it to get it out. That wire can only take so much tugging.
Is there any way to test if it's still a functioning switch, while it's installed?
Would you just ignore it?
The black rubber cap appears to have swollen in the hole. It's in there good.
Thanks.
Thanks.
