yes, the plastic threaded adjuster comes in both black and white....I've only seen them on crusaders.....most others used what I'll call a mercruiser mount.
The big difference is the crusader concept uses a single lag screw to retain the mount to the stringer and the donut is actually a large screw that does the vertical adjusting with the vibration dampener inside of it....the merc style has a pod (lag screwed to the stringer) for the vibration dampening and a vertical threaded shaft. the trunnion sits over the shaft and the adjustment is by the two nuts on the threaded shaft that 'capture' the eye of the trunnion.
the biggest drawback to the white donuts is they are fragile, esp if the wrong tool is used in their adjustment or the mount has started to corrode (added friction). being unique, they are not cheap...the good is they usually last the full life of the engine. the lags are drawbacks for both, over the long term, as they provide an entrance path for moisture in the stringer.....
