As the title says I have a 1995 Cobalt 222 with a DP-D1 drive that shifts into gear really hard. The motor and drive have 371 hours. I purchased the boat from the original owner. The boat sat most of its life with little use. I was told that the boat was difficult to shift the last time the owner had it in the water. I had the original shifter replaced with a Teleflex and also replaced the throttle and shift cable. Engine and drive fluids were replaced before launching the boat. My previous boat had Alpha drives on it so I was familiar with the way that type of drive shifts. I have read that the Volvo drives shift with an audible "thud", not sure if that is the correct way to describe it. The drive on this boat bangs into gear. It goes into gear so hard that anyone in the boat can feel it. The boat idles a hair over 600 rpm so that isn't the problem. I thought that maybe the shift cable wasn't adjusted correctly so I disconnected the cable at the drive and shifted it by hand. No change. When turning the shifting mechanism on the drive by hand it takes great force to put the boat into gear. When trying to move back to neutral I can't do it by hand because the force it takes to turn the mechanism causes me to overshoot neutral and go into reverse. With all of this being said once underway there is zero vibration in the boat when either accelerating or at top end. Not sure where this puts me at this point. I spoke to a local VP mechanic and he told me this is the way the "swedish" VP drives shift and that it is normal. Could be but I find this hard to believe. Any help is appreciated.
