Results 1 to 6 of 6
  1. Default Well, I gotta ask... Getting dead gasoline outta the tank... Bayliner
    1978 Bayliner Nisqually on a trailer -- anyone with a good idea on getting that stuff outta there? That juice is prolly 3 years old.
    My only thought is to open the sending unit access, slide in an old garden hose, get on the ground and suck -- I don't own a transfer pump.
    Any secret drain plugs I can't find?
    Dec 2015
    maplevalley WA
    5,049
    Default Re: Well, I gotta ask... Getting dead gasoline outta the tank... Bayliner
    It was You can remove the anti siphon valve on the tank and siphon it that way it just takes a while. You can burn the fuel up in your lawn mower i use my old ford pickup it dont mind.
    Apr 2013
    Lower Columbia River
    119
    I was replacing the fuel tanks on my boat and needed to remove the remaining gasoline. I found a flashlight-battery-powered pump that worked well for me. It requires a straight shot down into the tank as you can't flex the pickup tube. In my case, I was able to go through the tank's filler after the hose between the cap fitting and tank was removed. As I recall, the pickup tube is 13 inches from the inlet to "T" where the liquid is expelled. This is the pump: https://www.northerntool.com/shop/to...7825_200407825
    However you end up removing the gasoline, be super careful. Make sure the area is well ventilated. Remove all hatch covers. It just takes just one spark to set you and your boat on fire. It happened in my area just a couple years ago to two supposed professionals.
    Feb 2018
    Alexandria, VA/Dameron, MD
    14
    Hello,
    This was posted a while back but I had similar issues with some old cars that had sat for a while. In my view, gasoline is one of those areas where shortcuts can prove disastrous. None of us want to spend $ unnecessarily. I bought a 12V unit from https://www.gastapper.com/ and it worked great. Depending on the application, they also have gravity pumps which cost a good bit less.
    Bruce
    May 2010
    DC Burbs/Maryland Eastern Shore
    1,333
    Depending on your location, you can find professional services that will do this. Here in Maryland with gazillions of pleasure boats around, there are many many of these folks out there. Best to ask your local marina as they will probably be able to point you in the right direction.
    Getting the gas out is one thing, disposing of it properly is a whole 'nuther.
    Practicing the ancient art of ren-ching
  6. #6
    Feb 2018
    14
    Good point, there are a number of these services in the Chesapeake area. More expensive that DIY, but does solve the disposing issue. Bruce
  1. Grounding transfer tank to boat while fueling with gasoline ?
    By 37Dancer in forum Boat Fuel Systems (separate from engine)
    Last Post: 05-05-2017, 12:04 PM
  2. Gasoline in diesel tank
    By jansen in forum Volvo Penta Diesel
    Last Post: 04-28-2016, 08:58 PM
  3. Gasoline tank replacement
    By jersey31 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 03-27-2009, 09:27 AM
  4. Replies: 0
    Last Post: 04-11-2004, 03:14 PM
  5. Replies: 0
    Last Post: 04-08-2004, 10:31 PM
