Need Help Finding Correct Prop 1980 Johnson
dmeyer07
Hi guys I need some help finding the correct prop for a 1980 johnson outboard motor j20crcsa
Serial c8097154
I believe its a 20 hp 1980 Johnson
Thanks!
-Dave
Many props attach to the motor.----But a prop " fits " the boat and what you are doing with it.-----Post that information for expert help from some.
Thanks for the quick reply! I'm just doing casual cruising on the lake nothing fancy
It's a small 14 foot aluminum seafarer starcrat boat it is on
There are different pitches.-----Lower pitch for bigger boats / heavier loads.----High pitch for small boats / light loads.----Your local dealer may help.----I would put on a 9 diameter X 10 pitch.
You have to be very , very careful when you wander off on your own.------You need to look this up for a 25 hp model for 1980 model year !-----The postings / listings on some sites can and will confuse a novice !----You need a splined prop, but not one with through the hub exhaust.----Better to talk to your local dealer for accurate help !
