Click for Volvo Penta manuals!
Results 1 to 5 of 5
  1. #1
    Default Anyone chip their Volvo Penta diesels?
    Anyone have experience with chipping their diesels for increased performance? Not sure I am going this route but wanted to hear from those that have done it and if it was worth it? And are their inherent risks with doing this? Looking at a chip from "chip express" for D6-350.
    Thanks in advance for your help.
  2. #2
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    1,373
    Default Re: Anyone chip their Volvo Penta diesels?
    No idea but generally speaking your fuel consumption will go up, sometimes quite dramatically. If that's not a thing for you then I'd say it's worth a try. Is there any warranty issue with installing these on your boat?
    Also, simply adding horsepower to an engine will not necessarily make your boat go faster. There are lots of factors in play. Hull shape, payload, wave action, propellers, headwind, etc etc.
    Practicing the ancient art of ren-ching
  3. #3
    Thanks for your feedback. Yeah, this is for a Formula 400 SS which I assume should gain 2-3 knots. Not sure that's worth the risk, which is why I'm asking if anyone has any experience chipping these diesels. Either way looking forward to a good summer gents!
  4. #4
    Join Date
    Jun 2008
    Location
    Posts
    689
    Trouble with doing the chipping is that you can't use the power for extra speed unless you then increase your prop size (probably more pitch). That engine already turns at 3500rpm to make it's power so I don't think spinning it faster would be a great idea, so more power means prop changes to use it.
    Simple thinking suggests that chipping a marine diesel without adding more boost will just add hp at the expense of increased fuel burn. It could be however that the turbo might be able to provide the extra boost but how is that managed when you 'chip' the engine? You then need to know whether the cooling system will cope with the extra hp production, especially if it is just adding more fuel without increasing the boost/air supply. You could check the cooling system parts compatability between your D6 350 and the higher hp versions to see if maybe the cooling system has the extra capacity already. Bottom line is that you might be better off asking Volvo if your engine can be reprogrammed for the higher hp (370hp I guess?). I would be pretty confident that you won't get to the 435hp of the upper limit D6 with just a chip change. So the chip might be an OK idea but time to do some homework on what it actually does and whether the engine can handle it in tems of cooling. I would guess that the 350 and 370 internals are probably the same so wouldn't be too worried about that aspect unless the chip is claiming a lot more hp.
    Final comment is that a 5.5l engine making 350hp is a pretty solid 64hp per liter of displacement which is a decent recreational rating and even OK for light commercial use. Take it to the 435hp rating however and then you are nearly 80hp/liter which is not really a recipe for a long lasting engine. Modern injection systems certainly help but these engines aren't built super heavy like older diesels and there is only so much hp they can produce before needing rebuilding. Used to be that you counted a marine diesels life expectancy in gallons of fuel it can consume between rebuilds and I don't think that the picture has changed that much. Make more hp out of the same engine and then you get to rebuild or replace it that much earlier, plus you need to service everything that much more often.
  5. #5
    Quote Originally Posted by aliboy View Post
    Thank you for taking the time for a detailed response. My next step is to call Volvo and get a sense for what might be needed to get reprogrammed to 370. I will keep you informed.
Similar Threads
  1. Volvo Penta AQ150B | Volvo Aquamatic 250B
    By PCP in forum Volvo Penta Gas Engine Forum
    Last Post: 05-25-2016, 11:14 AM
  2. Volvo TMD 40 Diesels SN 17901 and 16825 circa 1983
    By Paul Blando in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 12-23-2005, 05:50 PM
  3. 1964 Volvo penta AQ180 Volvo B36B engine
    By hystat in forum Volvo Penta Gas Archive
    Last Post: 05-01-2004, 05:33 PM
  4. 36b wellcraft martinique with 230 HP volvo penta diesels
    By lanzetta in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 01-24-2004, 07:26 PM
  5. 36b wellcraft martinique with 230 HP volvo penta diesels
    Last Post: 01-24-2004, 07:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
