MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 8 of 8
  1. #1
    Default Water coming from the reverse lock rod boot
    Hello, I've got a 1964 Mercury 850 outboard. I've noticed that when it's running on the muffs and water hose that water comes out where the reverse lock push rod boot is, just wondering if this is normal or something I need to address.
    Thanks very much
  2. #2
    Default Re: Water coming from the reverse lock rod boot
    There should be a lower unit waterway or vent near that so it is normal. Very easy to plug them up with debris. You may have your water pressure set a bit too high also. You can make a lower unit leak with too much hose pressure.
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,945
    If the engine is not getting too hot go fishing.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,945
    Is there a grease zert there to pack the reverse lock cams?
  5. #5
    Thanks guys for the replies I really appreciate it. There is no grease fitting there.
  6. #6
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,945
    There should be a plug there for filling the reverse lock cams with fresh grease it takes a allen wrench to remove.
  7. #7
    There is a flat head screw I'm not sure what it's for. It's on the opposite side of the oil fill and vent screws. That may be it, I'll check it and see. It's about where those cams are.
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,945
    That is for a flushing adaptor that was never really used probably all stuffed up. If you look closer there is a set screw type of plug that goes to the cams?
Similar Threads
  1. aq 270 sterndrive reverse lock
    By Tito Marrero in forum Volvo Penta Gas Engine Forum
    Last Post: 07-02-2016, 11:44 PM
  2. Reverse Lock
    By alexman4 in forum Chrysler Force Outboard Forum
    Last Post: 06-26-2009, 12:24 AM
  3. Reverse Lock Cam
    By roon500 in forum Mercury Mariner Outboard Archive
    Last Post: 07-19-2007, 02:17 PM
  4. Reverse lock
    By greensnake2 in forum Mercury Mariner Outboard Archive
    Last Post: 05-21-2007, 09:00 PM
  5. Reverse lock cam
    By irvin in forum Archive 2003-2009
    Last Post: 05-05-2004, 08:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
