Results 1 to 4 of 4
    Default Yammie 1997 150 saltwater- 1 spark plug spotless clean as well as threads ??
    New to me yammie 1997 150 saltwater II - good compression even at 120 psi on all 6
    5 plugs look normal except bottom right (#5?) is spotless including threads- looks like it was put in and never fired- I understand that water will clean top of plug - but threads are spotless clean also- questioned seller- he says these were put in 2 years go- NO WAY - ?
    Sep 2010
    ontario
    15,544
    Default Re: Yammie 1997 150 saltwater- 1 spark plug spotless clean as well as threads ??
    Clean plug means no spark to that plug.---Or no fuel / too much fuel.-----Or no crankcase compression on that cylinder.------A V-6 runs very well on 5 cylinders.----Does spark jump a gap of 3/8" or more on all leads , yes or no.
    Just checked per your suggestion - yep 3/8" or more.
    Check spark on "clean" plug - all good. Guess I will fire up this weekend and and start pulling plugs wires to see it it drops a cylinder out-
    So I expect carb build next.
    Need a wiring diagram - end cut off one cable -
    Thanks for response-
    Found water in #2 and #6 cylinders. Tore block down- everything looks excellent except some cracks in front half of block- these go not go thur to machined surface inside.
    Drained on engine oil tank- it was full - after it set for a 1/2 hour in clear jar there was 3/8" "water" at bottom of jar. Since only 2 cylinders appeared to have water I do not think this is source of water in cylinders.
    Where is water coming from? Head gaskets did not look damaged.
  1. Stripped spark plug hole threads
    By mn_stranger in forum Mercury Mariner Outboard Forum
    Last Post: 04-19-2017, 07:59 AM
  2. Stripped spark plug threads
    By Clint1395 in forum Johnson Evinrude Outboard Forum
    Last Post: 03-27-2014, 08:13 AM
  3. stripped threads in spark plug port
    By davidm in forum Honda Outboard Forum
    Last Post: 06-05-2011, 11:51 PM
  4. spark plug threads
    By shimanok2 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-05-2011, 11:27 AM
  5. Stripped out spark plug threads
    By justinl50 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-20-2008, 11:58 AM
