MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
  1. #1
    Default Mercury tower of power 90hp question
    Hey guys..i have two older mercury 90hp outboard engines..one is a distributor model, the other is a electronic ignition model..is there any way i can change the power head portion of the distributor model to the electronic ignition model and switch that power head to electronic ignition? The leg and power trim and wiring/ignition system on the distributor model is rough and the power head on the electronic ignition model is blown..im wondering if its possible to build one from the 2 of them? Any input would be great..thanks!
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    3,035
    Default Re: Mercury tower of power 90hp question
    How old is the distributer model??? There are 2 different blocks 8 and 10 bolt. If the same you can put the distributor model powerhead on the newer midsection..
    Nope nothing is bolt on swap over. There are no mounting bosses for electrical plate and front half is different and should not be swapped as its 1/8 taller. Wont allow top bearing to seat. I have done it but its not worth the headache with all the makeshift brackets/spacers/standoffs/block machining.
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
Similar Threads
  1. Tilt & Trim motor n pump removal on 1986 mercury 90hp tower of power
    By albeckjr in forum Mercury Mariner Outboard Forum
    Last Post: 10-10-2016, 05:44 PM
  2. 1983 Mercury 90hp Tower of Power lower unit won't drop down
    By uncle dude1264 in forum Mercury Mariner Outboard Forum
    Last Post: 11-26-2014, 02:20 PM
  3. 90hp tower of power how to engage neutral?
    By brokensword in forum Mercury Mariner Outboard Forum
    Last Post: 07-31-2011, 03:05 PM
  4. 90hp Merc Power Tower
    By guido2 in forum Mercury Mariner Outboard Forum
    Last Post: 06-23-2011, 05:27 AM
  5. 90 hp tower of power question
    By Yellowstreak in forum Mercury Mariner Outboard Forum
    Last Post: 04-10-2011, 09:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
