MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 14 of 14
  1. #1
    Default Need kill switch on merc 200 20 hp
    Hello all...
    Ive been reading for years, finally joined up.
    I got an older merc 200 20hp. Its a 1969 model.
    It has no kill switch and i need to get one installed.
    Coukd someone walk me through this?
    Parts needed and some info.
    Ive done some work on my evinrude but never anything like this.
    Any info would be really appreciated.
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,988
    Default Re: Need kill switch on merc 200 20 hp
    Does it have the phasemaker ignition???
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  3. #3
    I believe it has the thunderbolt ignition. Though im not 100% on that
  4. #4
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,988
    Post serial # as kill switch works different on certain ignition systems......
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    What is the serial number of your motor?
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  6. #6
    The s# is 2250276.
  7. #7
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    That is a 1967 model is there a terminal block on the side of the ignition with two wires? If so any kill switch will work all your doing is shorting the two sets of points together. Do the plug wires go under the flywheel?
  8. #8
    The motor is at the shop getting a tune up so i cant check. It will be back in a couple weeks.
    Dang....
  9. #9
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,652
    It's a Phelon mag motor--lucky for you! (The later Phase Maker was a dog.) Any good switch will work yours.
    Jeff
  10. #10
    Quote Originally Posted by fastjeff View Post
    Jeff
    Ok..that sounds good. But how. Where do i get a switch and where do i wire it into.
  11. #11
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,244
    Are you looking for a lanyard type man overboard stop switch or just a stop switch ??------Best to find a boat shop for a switch or ask the shop to install one.-----No big deal.
  12. #12
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    Any marine start switch will work you should have a terminal on the side of the powerhead with two small wires from under the flywheel. Just connect the switch to those two wires.
  13. #13
    Ok... yeah i meed a lanyard kill switch. Im going to buy one and see if i can figure it out.
    Look for the wires and screw **** up. Lol
  14. #14
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,926
    You may need to remove the flywheel if the wires are not present but still easy enough to do take a couple pics of the sides of the powerhead.
Similar Threads
  1. Merc Classic 50 - Kill switch problem. Need help with parts.
    By Acleme2017 in forum Mercury Mariner Outboard Forum
    Last Post: 05-14-2017, 05:52 PM
  2. 1970 Merc 650 ignition switch won't kill engine
    By Joe Baublis in forum Mercury Mariner Outboard Forum
    Last Post: 07-31-2016, 07:11 PM
  3. Kill/Saftey Switch Install on 1987 Merc 25HP
    By rmcderm313 in forum Mercury Mariner Outboard Forum
    Last Post: 10-30-2013, 09:02 PM
  4. kill switch problem 1976 85hp merc
    By wjcap4 in forum Mercury Mariner Outboard Forum
    Last Post: 08-26-2011, 08:11 AM
  5. Neutral safety switch versus shift kill switch?
    By Pal in forum Mercruiser Sterndrive Forum
    Last Post: 10-26-2010, 01:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
