whaler_warner
Following on from earlier threads, I purchased the above outboard partially stripped and in unknown order (it came "free" with the boat but was apparently in working order and was stripped to paint the block which has flaking paint).
having purchased the wiring loom I now have everything wired up to the forward controls, starter motor back on, oil tank back on filled and bled at the oil pump and hooked up running on pre-mix just to be safe.
Couple of questions which I cant find from the manual or parts list catalogue (its a 1995 90hp M90a power trim/tilt):
1. Battery Negative, does this go to the starter motor? they usually do but the parts manual doesn't shows it going to the start but what I think is the earth point on the motor? I put it to the earth point and everything seems to work but when cranking the motor over the negative wire gets warm.
2. Trim only goes down and not up, no click when pressing the up on the controls. I am not overly worried as long as the trim motor works its one less think to fix and guessing its just a relay or maybe the switch?
TIA
TIA
