Click for Volvo Penta parts and manuals!
Results 1 to 8 of 8
  1. #1
    Default Good Reference for General Repairs/Maintenence VP AQ280 Outdrive
    What is a good, easy to follow, written source of general fix-it guidance for a 1978 VP AQ 280 outdrive? Iím about to replace the U-joint bellows. Youtube and SELOC are not too helpful.
    Thanks,
    Mark
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
    Default Re: Good Reference for General Repairs/Maintenence VP AQ280 Outdrive
    Its pretty straight forward lower the drive fully and unbolt the upper gearbox after you drain the oil. Carefully lift up the gearbox and be aware of the shims for the lower bearing. Replace the u-joints while itis apart and wouldnt hurt to replace the water hose and housing on the inter housing. Then put it back together with new o-rings always.
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    10,250
    I spent approx 24 years doing AQ series work exclusively, and have posted many times re; the How-Tos regarding this type of DIYr work.
    I would suggest doing a MarineEngine dot com forum search in the Volvo Penta forum.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    Ricardo,
    First of all, thank you and the other folks for all the advice you've given me as I replace parts on this stern drive and the assistance on other engine and drive issues in the past.
    I'm going with dropping the transmission method of U-joint bellows replacement. Couple of additional questions. Is there a best order of replacing exhaust bellows and U-joint bellows (over the same weekend which bellows to replace first)? Is there a specific sealant or lubricant that should be used on the contact surfaces of the bellows (exhaust and outdrive)?
    I think I have gathered all the recommended VP parts (bellows, O rings, gaskets, hose connector, etc.). All these parts are VP - not aftermarket.
    Incidentally, on follow-up to past discussions on where and how to get the external exhaust flapper for my AQ280, I finally found part number VP852644 on ebay. It fits right on without modification -$32.00. If anyone needs one of these items there are a few left on ebay site.
    Again, thanks
    Mark
  5. #5
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    10,250
    Quote Originally Posted by shadetreevet View Post
    Ricardo,
    You are certainly welcome.
    Mark, according to my sources, the 280 exhaust outlet flapper was offered as a production item only. In other words..... this part was never available over the counter.
    I would like to see the e-bay auction for one of these!
    Portland, Oregon
  6. #6
    https://www.ebay.com/itm/VOLVO-PENTA....c100033.m2042
    It's got a short cut in the flap surface so it can fold a bit in the middle but installed it seats in very nice.
    If the website doesn't open I'll try something else.
  7. #7
    Join Date
    Jun 2014
    Location
    Arizona
    Posts
    162
    eBay can certainly be a treasure trove of hard to find NOS Volvo Penta parts. I actually look there first before looking anywhere else.
  8. #8
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    10,250
    The Volvo Penta p/n 852644 is for the 290 (and similar) lower gear unit housings. It is shown as SEQ # 6 here.
    http://www.marinepartseurope.com/en/...-44-17633.aspx
    As said, the 280 exhaust outlet back-flow prevention flapper was offered on production units only.
    In post #6 (
    in this old thread) you can see what this rather rare and unique part looks like.
    http://www.marineengine.com/boat-forum/showthread.php?441819-AQ-280-Exhaust-Bellows-Replacement-Part-Number-Conflict
    However, with a bit of modification to both the flapper and the housing, the 290 flapper can be made to work on the 280;
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Exhaust outlet 280 and 290 lower.jpg
ID:	17172   Click image for larger version.
Name:	Exhaust flapper retro fit.jpg
ID:	17171   Click image for larger version.
Name:	Exhaust outlet  290 SP DP and later.jpg
ID:	17173   Click image for larger version.
Name:	Exhaust outlet styles.jpg
    Portland, Oregon
Similar Threads
  1. AQ225E engine, AQ280 outdrive
    By Damjan Slapar in forum Volvo Penta Gas Engine Forum
    Last Post: 07-15-2014, 07:58 AM
  2. Volvo Penta AQ280 DP Outdrive removal
    By nicholas0 in forum Volvo Penta Gas Engine Forum
    Last Post: 03-05-2011, 12:19 AM
  3. Thread repairs on 280 outdrive top Dipstick Oil fill hole
    By fbfrmkd in forum Volvo Penta Gas Archive
    Last Post: 06-04-2009, 10:13 AM
  4. Doing some maintenence PLEASE HELP
    By CharlesBasowski in forum Volvo Penta Gas Archive
    Last Post: 07-02-2008, 04:21 PM
  5. b04 200 HP Mercury SW EFI 25L Maintenence
    By al966 in forum Mercury Mariner Outboard Archive
    Last Post: 04-28-2006, 11:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
