Bravo 3 drive shaft play
Chrisvr6
Had to repair the drive shaft seal because of a leak. Set rolling torque, torqued the retainer with the special spanner tool. There is some in/out movement now when i pull/push the drive shaft in and out. Did i not torque the big retainer enough?
Going by the torque conversion chart for that spanner. Shows i have to set a 17" long torque wrench to 144 ftlbs to get 200. Will have to check again i guess.
