Results 1 to 10 of 10
  1. #1
    Join Date
    Jul 2014
    Location
    Florida
    Posts
    346
    Default Can you use a boat ramp as a test tank?
    I used the Joe Reeves WOT spark advance setting method on my 115hp Johnson. I did the same on a 25hp, but in that case because the boat only went 24mph at WOT, I could "safely" also check it on the water running at 24mph. I found that the spark advance was off the target and I adjusted it accordingly. I'd like to test a 70hp and my 115hp on the water, but they go too fast at WOT.
    I saw some boat yard test tank videos on YouTube and it just looks like they made a boat ramp and back the trailer into it. Can I just back my trailer into a boat ramp and do a WOT test to verify the spark advance is OK? If I strap the boat onto the trailer and leave it hitched to the truck, will the boat thrust break the trailer winch post and hit the truck or something? I look at the videos and do not see much thrust/push forward on the trailer and they are running even big twin engines.
  2. #2
    Default Re: Can you use a boat ramp as a test tank?
    Find someone else to drive the boat. Your prop could also wash out material at the landing and could cause issues for someone else
  3. #3
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,554
    Ever heard of a " test prop " for these motors ?
  4. #4
    Join Date
    Nov 2011
    Posts
    1,980
    You might not get caught or worse, but that practice is destructive to boat ramps. What if everybody did it? If nothing else. tie it up securely to the pier. And hope it doesn't pull your cleats off the boat.
    Seriously, the right way is use a test prop. Yes, they are expensive, and yes that is why the shop charges to do the job.
  5. #5
    Join Date
    Aug 2008
    Location
    Mims, FL, USA
    Posts
    1,654
    PM sent
  6. #6
    Join Date
    Apr 2010
    Posts
    4,321
    You can take a damaged prop, cut the blades off equally and make a test wheel out of it and use it at the dock. OMC used to have specs on what to cut off for the HP mtr you had.
  7. #7
    Join Date
    Jul 2014
    Location
    Florida
    Posts
    346
    No big deal, I am satisfied with the results I got with the Joe Reeves method on the 115hp, and the 70hp should be fine, since it belongs to a friend who used it since it was new 25 years ago. I just was wondering about using a ramp.
  8. #8
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
    Its a simple adjustment to do out on the water and normally never needs to be touched unless you messed with it. The throttle pickup adjustment needs to be checked/adjusted when you pull the carbs.
  9. #9
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    3,035
    Test prop +ramp=no damage to either.
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  10. #10
    Join Date
    Apr 2010
    Posts
    4,321
    Fatz, Well said. Been there and done that.
Similar Threads
  1. Need help for a test tank
    By spencer591 in forum Miscellaneous marine engine topics
    Last Post: 07-29-2014, 06:57 AM
  2. Small Outboards: Sea test Vs. Tank test
    By skiffscott in forum Johnson Evinrude Outboard Forum
    Last Post: 04-24-2010, 01:18 AM
  3. Test Tank
    By lucky_d in forum Mercury Mariner Outboard Archive
    Last Post: 09-02-2009, 07:28 AM
  4. Ramp talk
    By farnsp in forum Johnson Evinrude Outboard Archive
    Last Post: 07-26-2007, 08:11 PM
  5. Tank Test or Muff Test
    By silkscreeners in forum Johnson Evinrude Outboard Archive
    Last Post: 04-30-2007, 04:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
