1978 Montgomery ward sea King 35hp outboard flywheel
Patrick88
So we were removing the flywheel and it broke. Now I'm catching hell trying to find a new flywheel. S/N 30035 on the motor. Stamped number on the flywheel is fwm2016. Can't find it anywhere.
Were you using a jaw type puller? There are a bunch of 1978 chrysler 35hp flywheels on ebay that should work. Part #f529097 id that electric start? You use a three bolt harmonic balancer puller with long 1/4 20 grade 8 bolts screwed in at least five threads.
Looked closer and you probably have the points type flywheel # F460097 also available on ebay. If it does not have the bolt holes go ahead and drill and tap them with the flywheel off you will see the indents for some reason the factory stopped doing it probably to save costs? The other flywheel is for the alternator type system with one big round magnet?
