JohnnyBouy
Hey everyone! Attempting to do my first rebuild, and I've got it torn down so far.
It's a 1974 Johnson 9.9
Just looking for some input (still very new with motor repairs).
Issues encountered so far:
So, at a minimum I think I'm looking at:
I've never done any work with teardown before, so I'm not sure the extent of this damage/if it will cause minor or major issues in the long run?
Mainly, I was just wondering if the rebuild is worth it, or should I sell the motor for parts?
Any input is appreciated!
- Bearing Housing on the lower unit is cracked/broken at both bolts (will need to be replaced - minimum $50?)
- Several bolts on the powerhead sheared off during disassembly (haven't put any effort into getting them out, but could cause issues)
- Top piston head has some damage? (In picture below)
- Coils are super rusty (Is this an issue?)
- Carb has a crack in it from somebody trying to unbolt it (looks like they attempted to seal it) (Is this no good?)
- New gasket kit/set ($50)
- New/used bearing housing ($50+)
- Misc cleaning supplies ($50)
- Paint/primer/sealant/antisieze for bolts ($75-$100?)
