It gets confusing when someone uses the word crank. Does it turn over and not start? Or is the starter not turning (wont crank over)?
Yep... Sure as hell does. Here's something (below) that a fellow member typed up quite some time ago. Haven't seen him around lately, however I saved what he had to say as obviously I thought it worth saving.
"(Crank vs Start Explanation)
(By member "Xcuseme" of another forum)
The following was posted by a forum member and friend (Xcuseme) as an explanation to eliminate confusion pertaining to their term of "Cranking" vs "Starting". I thought it was well worth saving for re-posting when needed. His post of years ago is as follows.
"OK, I see where this is going..it's all about terminology. Cranking or 'to crank the motor' is the act of rotating the crank shaft (and flywheel) of the motor. By pulling the rope of a rope start motor OR using the starter to accomplish the same thing, you're cranking the motor. Cranking the motor is NOT starting the motor, but you do have to crank the motor in order to start it . Unless the ignition has been disabled, cranking the motor will normally start the motor.
The motor should not be running when doing a compression test. Disabling the ignition system does 2 things. It prevents the motor from accidentally starting and protects the ignition system from damage.
A recent poster said " My motor won't CRANK up".......this is confusing. Others will then ask " Are you saying the motor won't START or are you saying the motor won't turn over (rotate) because of a defective electric starter. The poster would have made things clear by saying 'My motor won't START up'. The terms Crank and Start are not interchangeable."
