Dear All,
I'm facing an issue with my BF90A, when I increase the RPM above 4000 RPM overheating alarm starts beeping. I noticed yesterday when I was cursing around 3500-4000 RPM the pee hole got clogged, it was dipping water slowly "" it happened long time ago this is the second time "" I put my finger in the peeing hole tube to build up pressure after 2 seconds flow got back to normal flow speed.
things been done 2 months ago,
1- new head gasket '' cleand the cylinder water passages were clogged.
2- new valve spring "spring relief"
3- new Impeller.
Any advice how to diagnose the problem?
" I tested the temp sensor if it was giving me fault alarm, sensor is working perfect.
3- new Impeller.
