Marine Supply in Gulfport Mississippi has LOTS of salvaged Honda parts. I wouldn't hesitate to use a water separator from them. They close early on Saturdays call before 12 for a price.
(228) 896-9651
I'm surprised that your engine has the float sender on the fuel/water separator. Didn't think those were added until 2005.
The earlier 225's didn't have that float switch. If you have a good 10 micron external fuel/water separator, and you change that filter element every 100 hours, you may be able to get by with a broken switch on the on-board F/W separator. In 2200 hours of operation, I've never found any water in the on-board separator - it's all been caught by the external separator.
Yes. Your '02 does not have the sending unit, thus no wires coming out of the bottom of the bowl. Mhelton's '04 apparently does. As I said in the previous post, I didn't think they used those until 2005, but obviously I'm wrong about that. It's basically a very simple float switch. If enough water gets in the bowl, the float moves up in the bowl and makes a connection in the switch, setting off rapid beeps on the alarm.
Test the F/W separator when you get it. With separator right side up - no continuity on the wires. With separator upside down, full continuity. Make sure the float moves up and down easily inside the bowl.
Yep - scrape & vacuum - CAREFULLY. When finished, treat with white vinegar or CLR. Let it sit for several hours, then flush.
That looks pretty bad. I would consider doing some grinding with a Dremel then filling in the big pits with something like JB Weld or similar. Don't know if long term exposure to CLR will cause any problem. I think you would fine if you use white vinegar.
I've not personally had this problem, but I know others on the forum have, so hopefully one of those folks will jump in.
Sounds like a good fix. Hopefully, it will hold.
Well, the "oil" argument crops up about once a year on this forum. And their are opinions all over the place.
First, given the age of that engine, I (and several shops I know in my area) recommend going up to SAE 25W-40 instead of the Honda-recommended SAE 10W-30, unless you operate in an exceptionally cold area.
My opinion on oil is as follows: If the engine is run year around, or nearly so, stick with a good grade of marine petroleum-based oil (API service category SJ or higher) and change the oil religiously every 100 hours or every season, whichever comes first. If engine sits up for long periods of time, then a synthetic-based oil MAY be better. Don't know for sure. If you decide to go with a synthetic, you should still change the oil every 100 hours.
