new to the board and the site...seems you guys are pretty sharp.....see if you can possibly help me!!!
this is exactly what I have going, but I do not see a relay on the front as he described. ???
turn the key on, one long beep (as normal), turns over fine. good compression all 8 holes.
http://www.marineengine.com/boat-forum/showthread.php?288211-Which-outdrive-is-it&goto=nextoldest
I got a 2002 four winns funship, 5.7 GI-B with Volvo SX drive, I have no spark or fuel pumps going....here is what I have done
replaced the coil AND ignition module 3 times, independently, with 1 known good, 1 new aftermarket, and 1 Volvo OEM. (all in different configs)
checked the neutral safety switch, and the lanyard, and jumpered them both, same result.
checked all fuses and relays, and swapped relays with known good ones.
checked the ignition switch, and then even replaced it. same result.
removed distributor cap and looked for anything obvious...(burned contacts etc) nothing
problem is whatever it is, is affecting BOTH systems.....ANY IDEAS??? thanks!!!
