My kids bought an old boat. 1965 Traveler Atlas 16' with 1971 Evinrude 50173s 50hp 2 stroke. Cleaned up the carbs an fired right up after 20 years of not running. Did all the normal stuff... new impeller, new coils, solenoid, fuel filter/fuel pump, and new gas lines. after running a while it started bogging. inspected everything a found a deteriorated fuel pump. The rubber inside seemed to melt. cheap after market one. put old one back on and ran but bogging still. Pulled the carbs to clean again. I received new rebuild kit but used old needle valve retainers. the new ones in the kit are red and rubber. very difficult to screw the needle valve through. should I use the old ones or suffer with the tight fitting, almost impossible to screw through, retainers? will upload pics later. have shop manual coming.
