brickmaster587
Hi, I've got a 1957 Evinrude 5.5 with very stiff steering.
I tried moving it back and forth a ton and it has freed up a bit but it's still not smooth enough for usage.
I took the motor off its cradle and removed the handle/throttle assembly from the top of the pilot shaft. I've tried whacking the bottom of the shaft with a rubber mallet and a dead blow hammer but it just will not come out. I've looked and looked and I can't see anything that would be holding it in.
I soaked the mounting bracket/pilot shaft assembly in a solvent tank and it has freed up some more but still takes quite a bit of effort.
If someone has any insight on this problem the help would be much appreciated!
