masterknowitall
Hi all. I have a 73 Mercury thunderbolt 650. The engine cranks but won't start. When cranking the engine remotely with key on and plugs out I have a very strong spark from each plug wire separately (cranks well with key too).I've gone through the carbs and all seems fine. I do have a kill switch that feeds ground or absence of ground to the brown wire attached to the switch box. In the spark test above, I had strong spark with the(brand new) kill switch in either mode which puzzles me.. I have also added mixed fuel to each cylinder and the best I get is an occasional pop, which has the sound of the timing being way off and a puff of smoke from the prop. However, the timing appears to right. I carefully soldered in a new ignition switch and I have continuity everywhere I'm supposed to have it. I'm a master certified car mechanic but not a 2 stroke genius at all. I'm frustrated and stumped. I've done every electrical test I could think of and read about and what I'm finding seems to be ok although I don't have a dva to do it correctly. Any help, suggestion, question or guidance would be greatly appreciated. Thanks
