Results 1 to 9 of 9
  1. #1
    Default I969 Model 40973R 40 HP Evinrude Tachometer.
    I would like to know how to set a 6M or 7M Tachometer and how to connect to a 'Generator' ?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,875
    Default Re: I969 Model 40973R 40 HP Evinrude Tachometer.
    Is your motor electric shift ?---Do you have the generator / voltage regulator and the belt ?----Where did you get the tachometer ?
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,656
    Good question i believe the tach requires AC pulse and a generator produces DC voltage. I am not sure if you can pull a pulse from one of the ignition coils for a standard inboard tach? Tiny tach makes a induction type you just wrap around a plug wire and mount close to or on the engine it gives you rpm and hours. A single pulse from a two stroke is the same as a two cylinder four stroke with adistributor. The tiny tach would be a sure thing.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,656
    The TT2A can be ordered with a longer coax from the factory it comes with 6foot standard coax.
  5. #5
    Quote Originally Posted by racerone View Post
    Yes, it is electric shift, with Generator, Voltage Regulator and Belt. Tachometers are from previous boats in the past.
  6. #6
    I presume Marine Engines.com would carry?
  7. #7
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,656
    Ebay or amazon
  8. #8
    Thank You, getting ready to look.
  9. #9
    TT2A Tach has been ordered off of ebay, almost two weeks, still waiting.
Similar Threads
  1. Evinrude model#115793S Tachometer
    By hotrod 2175 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-08-2010, 12:10 AM
  2. 1969 Evinrude 40 hp model 40973R
    By ronnysho in forum Johnson Evinrude Outboard Archive
    Last Post: 04-14-2007, 07:29 PM
  3. 1969 Evinrude 40 hp model 40973R
    Last Post: 04-01-2007, 08:53 PM
  4. Newby 1969 Evinrude 40 hp model 40973R
    Last Post: 03-31-2007, 10:33 PM
  5. Johnson 50hp model 50ES71 Tachometer
    By jerry in forum Outboard motors archive 2000-2004
    Last Post: 05-09-2002, 12:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
