What happens if you pump the primer bulb ??
I do not believe it has S.L.O.W on that model.
Racer is correct.......... I checked the book, S.L.O.W. is not featured on that 1990 90hp model.
After 10/20 seconds, you say the engine slows down and you indicate that the engine is not overheating which is logical as it would take a longer period of time for the engine to overheat. You also indicate that there is no fuel restriction as you are able to pump the fuel primer bulb while the engine is running and the rpm does not change.
This slowing down....... Is it a gradual slowing down of the engine ... OR... a sudden instant drop of rpms?
It is a quick drop-off of power. I haven't gotten a tach for it yet, I just got this motor recently.
I have the service manual ordered. Should be here next week.
not to derail this thread, but where did you order the service manual from? I've looked for a while and found nothing... other than ebay vintage manuals that want too much $$. I'm going to be replacing the powerhead on a '91 90hp and i'd like to have torque specs and proper procedure, etc.
