Rileym1989
Hi everyone. I'm a first time boat owner that's having some issues so I figured this would be the place to get some help. I just picked up my first boat on Saturday, it's a 24ft pontoon with a 110hp oil injected Johnson and omc controls. When I first looked at the boat, everything worked. The p.o. started it up and showed me it spun the prop both directions and the power tilt worked without issue. After I decided to buy it, i raised the outboard with the trim switch for transport, then hit the down button to lower it on the locks but nothing happened. The tilt would not move the engine up or down and now the key will not start the engine. I got the boat home and started messing with it but have had no luck finding a simple fix I was hoping for. I've checked the battery and connections which are fine and also checked the master battery switch which is working fine aswell. Am I missing something simple on this engine? All the lights work and so does the radio so I know it's getting power. I also can jump the starter and it will turn the motor over(I didn't do this long enough to see if it will start) so it seems the engine is well grounded and has good battery power. Any help would be appreciated. Thank you
