How do I test to see if my oil sensor is bad (12430a4)?
Where can I find the steps to test my oil warning module (41470a11) ?
Should the beep emanate from the oil warning module or from some other area??
Sorry...I am a noob....but could not pass up a 1984 ranger 392 with a 200hp motor...for $450...including tandem axle trailer with brakes !
Never had an outboard. this is turning into a great learning experience. Motor had not run in 15+ years. I rebuilt carbs and fuel pump. had sprayed and turned some oil in the cylinders about a month before test firing. Fresh gas and oil and she turned right over.
Engine runs with water to the "headphones"...I am a noob....but know to run water thru it when it runs.....never heard beeping. pulled the plugs and there is traces of oil on them. smokes like a chimney so I know there is oil mixing in the fuel....
Please be kind to the new guy.....
