Click for Honda Manuals, Parts and Model Guides!
Results 1 to 8 of 8
  1. #1
    Default Bf225 2012 , keep doing o2 sensors
    Hi guys
    Every so often 5-6 months Iím doing o2 sensors . Over here they are quiet expensive . My question is can I link the wires or do something so they are not in the equation, normally they go after Iím reversing around a bit to fast . I know this is probably not the best way to tackle it , but once u put new sensor in they donít seem to last . Ps I have checked and replaced the gasket on housing , was ok
    thanks Jason
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,901
    Default Re: Bf225 2012 , keep doing o2 sensors
    HO2 sensors failing that often is really weird, and really expensive. As I posted in your other thread, how are you determining that it's the HO2 sensor? A fault code "1" could be a misfiring spark plug, a failing coil, or fuel pressure out of specs. My 2007 BF 225 is still running on the original HO2 sensor even after 2200 hours.
    One thing that will blow an HO2 sensor is water getting up into your exhaust pipes. Your exhaust outlets on the back of the engine should be at least 5.9" above water level when the boat is at rest. The higher the better. Another issue is starting procedure: Once you start to crank the engine, you should keep cranking until it starts. "Bumping" the starter can suck water up into the exhaust tubes under certain circumstances. Finally, be sensitive about when and under what circumstances you turn off the engine while on the water, especially in high seas or a strong following sea. When the engine is running, even at idle, there is always a positive pressure on the exhaust tubes, which prevents water intrusion.
    The first thing I would do is make sure that the HP fuel filter is good (change it if in doubt) and the fuel pump filter and screen on top of the fuel pump are clean. They all have an effect on fuel pressure. See items # 7 & 8 at:
    http://www.boats.net/parts/search/Ho...ING/parts.html
    Then test the fuel pressure. You can do that through the fuel pressure relief bolt on the top of the HP fuel filter cover. That's part # 42 at:
    http://www.boats.net/parts/search/Ho...SSY/parts.html
    Fuel pressure should be between 42 and 49 psi.
    I would also pull the spark plugs and inspect the electrodes for fouling, or an exceptionally clean plug, which would indicate water intrusion in that cylinder. If plugs are good, they should have a milk chocolate brown coating on them.
    Next, I would closely inspect the wires from the ECU to the HO2 sensor - there are four, two for the heater element, and two for the sensor element - to make sure all connections are sparkling clean, and there are no chafes or rubs on the wires.
    Finally, test the HO2 sensor itself. There is a specific (complex) procedure in the Honda Shop manual, but here is a link to a general testing procedure for HO2 sensors:
    https://www.autozone.com/repairinfo/...&subtitle=test
    CHawk 25 DLX
  3. #3
    Quote Originally Posted by Jasoncop View Post
    Hi guys
    thanks Jason
    Hi Jasoncop,
    I write from Italy and I live your same experience.
    BF 250 and BF225 (after 2007) have the same o2 sensor 35655-ZY3-C01.
    On my BF 250 five o2 sensors were broken in 360 hours, the first four lived about 40 hours each, the last about 200 hours.
    I hope the greater life of the last is not accidental, I hope it is the result of a Honda attempt to solve the problem.
    Certainly the problem has a solution because on my boat for 8 years and about 1000 hours was
    mounted a BF225 (2004) that never had o2 sensor problems, but on my BF225 it was mounted the
    35655-ZY3-013 sensor, which is very similar to o2 sensors mounted on cars, instead the
    35655-ZY3-C01 sensor, which breaks frequently, is much smaller and certainly more fragile.
    I would like to know if the last o2 sensors mounted on your outboard have had a longer life
    I’m wondering if the OP ever got the situation fixed.
  5. #5
    Quote Originally Posted by Steve Singerman View Post
    Iím wondering if the OP ever got the situation fixed.
    No never got my problem fixed , still do o2 sensors every 6 months to a year , cost over $300 Australian dollars to fix .
    got twin bf225a so works out expensive ,
  6. #6
    Join Date
    Sep 2008
    Location
    Posts
    4,901
    There is someone on this forum that posted an NKG equivalent HO2 sensor which was considerably less expensive if I recall correctly. Sorry I cannot recall who that was, but search this forum and see if you can find it.
    As a side note, the HO2 sensor on my 2007 BF 225 is still the original at 2200 hours and no problems so far. I recently helped a buddy on pulling maintenance on his 2009 BF 225 with the original (22mm base) HO2 sensor and same story - original still good based on inspection of spark plugs.
    CHawk 25 DLX
  7. #7
    I’m using the ones made by walker and they were $90 had them in for three months so far so good part # 932-24008
  8. #8
    Join Date
    Sep 2008
    Location
    Posts
    4,901
    And the NGK part number is 932-24008
    CHawk 25 DLX
Similar Threads
  1. Bf225 2012 engine alarm
    By Jasoncop in forum Honda Outboard Forum
    Last Post: 01-11-2018, 04:03 PM
  2. O2 Sensors
    By Shark Bait in forum Honda Outboard Forum
    Last Post: 08-12-2014, 08:34 AM
  3. Honda BF225 Need help reseting the ECM for o2 sensors
    By skycat081 in forum Honda Outboard Forum
    Last Post: 01-03-2010, 08:17 PM
  4. SENSORS ANY HELP
    By joe_k in forum Johnson Evinrude Outboard Archive
    Last Post: 07-30-2009, 09:33 PM
  5. Trim sensors and trim limit sensors
    By Greg Wilcox in forum Mercruiser Sterndrive Archive
    Last Post: 07-01-2008, 12:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
