86 Alpha 350 V8, Reverse has been ratcheting (slipping with clank/click) more and more under load over the last season. I have confirmed full stroke at the shift cable (engine back), so I am reasonably certain the dogs are in full engagement. I know there is a lot of linkage left, but given that, I want to see what a season plus of ratcheting has done to the reverse dogs, and that the water pump is new, going in from the bottom seems just as easy. At rest in full reverse I can turn the prop either way with moderate force producing a loud click/clank. Forward drives fine, strong and quiet. The control cables have been fine tuned with at least 3 of the prevailing methods. If the clutch stroke or the dogs are bad I'll replace rather than repair. With 1200 hours how many good parts are left? As a new owner I am suspecting a previously weak cable setting may have damaged the R dogs? Thanks
