Results 1 to 13 of 13
    Default Water in oil just appeared BF 225 A
    Hi guys well got my engine up and running again and found a spot behind the mount for the loom connectors on the front of the engine where water was appearing at around 3000 rpm it would have been going on for a bit as there was a little corrosion on the bolts ,
    I just had an issue when I first got the engine it had a water leak at the base of the valley between the heads, I made a fix with a plug and some devcon and its held out for the past 3 years , it started to leak again so pulled it down and fixed it good this time , whilst test running I noticed some water coming from the front of the Crank case cover there is a round section with like a spiggot around it and what looks like a nipple , water was coming out from here.
    I have since found that there is now water in my oil, there was no water last week and the oil was clean as a whistle , the engine runs fine idle's fine no alarms I am guessing this is going to be a full tear down job
    might be time for a new engine case perhaps
    Any thoughts just putting it out there for ideas cheers guys Tommy
    Sep 2008
    Hague, Virginia, USA
    5,126
    Default Re: Water in oil just appeared BF 225 A
    In reference to the water leak, a couple of pictures would help.
    As for oil in the water, as a general observation, I would try to eliminate all other possibilities before a tear down. Pressurize the oil pan to see if you can determine the exact location of the leak. That takes time and patience and a good stethoscope.
    There is a water line that goes through the oil pan. There is a grommet that can fail and put water in the oil. See # 6 at http://www.boats.net/parts/search/Ho...PAN/parts.html
    Just some initial ideas.
    CHawk 25 DLX
    2 common places for water to enter into the sump would be the main oil pan gasket that is between the base of the power head and top of the oil pan ,the other would be through the cylinder head gasket what you can do is remove the leg then the oil sump make a adaptor to fit where the grommet fits into and connect water under pressure then sit under the oil pan and observe. the grommet chawk_man is referring is on the outside of the oilsump
ID:	16912Not sure how clear it will be but this was where water was coming from
    Sep 2008
    5,126
    OK, that's the same place that was discussed in a recent post from SophiaDa1st. See the following link.
    http://www.marineengine.com/boat-for...-is-trimmed-up
    No one seems certain what should go in there, but clearly something does. Contact SophiaDa1st and see if he figured it out.
    CHawk 25 DLX
  6. #6
    If you have the vst vent pipe that goes down to the oil pan in the wrong place and the water tube coming from behind the vst as on the 130 hp you have to be careful the 2 pipes are on top of the oil pan near the dip stick are very close together if you mix these 2 pipes around water will enter into the oil pan.
  7. #7
    thanks fortunately I never disconnected any water pipes I removed the inlet manifolds to get in behind where there was a small corrosion hole that was fixed with a plug , this has been repaired for 3 years and only effected the water jacket easy fix and has given no trouble
    I have a feeling there is something more sinister at work , before I topped up the oil there was no problem at all with the system im going to tear it all down and really go to town I think
  8. #8
    Sep 2008
    5,126
    Well, I'm fairly convinced that something goes in that hole, but I cannot figure it out. There is nothing in the various parts diagrams and there is nothing in my Helm shop manual that I can find. My only guess is that there was some sort of pressure relief plug (akin to a freeze plug) that goes in there. In the thread I referenced earlier, SophiaDa1st had oil coming out of that hole when he tilted the engine up.
    If you have water coming out of there, that is likely a really bad situation, since that piece in the picture is just the crank case cover.
    CHawk 25 DLX
  9. #9
    What was the verdict on this problem?
    Went out today and had what I think is a hole in block or head on number 6 and took on an extra 12 litres of water added into the oil. And have water coming out of that hole.
    It must be a pressure relief plug ?
  10. #10
    Quote Originally Posted by Interested ozzie View Post
    If I might make a suggestion? Rather than drag out a 5 year old thread like this, maybe start a new one? It might draw more of a response. Just make sure you provide some detail regarding your issue. Best of luck!
  11. #11
    Nov 2009
    temecula, ca., usa
    4,314
    Interested Ozzie,
    Asking questions here is certainly ok but I agree that starting a new thread would likely get more "focus" on YOUR problem.
    Good luck.
  12. #12
    Did you ever figure out what the problem was?
  13. #13
    Apr 2018
    1,702
    The hole in discussion is the flywheel housing vent, nothing should come out of it
  1. Stripes of bare aluminium appeared on outdrives
    By Samsara in forum Mercruiser Sterndrive Forum
    Last Post: 07-16-2013, 05:38 AM
  2. Replies: 0
    Last Post: 06-24-2013, 04:17 PM
  3. tohatsu m40d new water pump losing water before it gets to upper part of motor
    By Joel Caillouet in forum Nissan Tohatsu Outboard Forum
    Last Post: 08-06-2011, 12:09 PM
  4. Bravo , low water flow to sea water pump. Possible water fitting?
    By jon_allen in forum Mercruiser Sterndrive Forum
    Last Post: 08-05-2011, 01:18 AM
